I have two different transformers. One is designed with UL class 180 C insulation, with a 115 C temperature rise at a maximum ambient of 40 C. The other transformer has 130 C insulation system with an 80 C temperature rise.
Can I expect the transformer with the lower rated insulation to operate at less temperature than the transformer with the higher rated insulation? At ambient the temperature rise will only be 80 C whereas the other transformer will have, or is at least rated to have, 115 C temperature rise?
Is this a positive or a negative? Obviously with the lower rated insulation I do not have much room to go above ambient condition. The higher rated insulation gives me 25 C separation from the temperature rise and the rating of the insulation, whereas the lower rated insulation only gives me 10 C for winding hotspots.
