Hello.
I may be involved with replacing 15 yr old interconnected smokes in a townhouse/condo organization.
They are also requiring co2 detectors to be installed.. (can be plug into receptacle type)
I gave them numbers for replacing smokes with smokes, and replacing smokes with combo co2/smokes at bed room areas...
Reading around about the co2's it's suggested to put 1 at each level, basement for sleeping etc... guess the more the merrier.
I talked to the property management, they said their green card (?) treats these units as a hotel... they say the township fire inspector treats it as a dwelling unit (single units).
The current wiring is 120v in each unit ( 1-3 interconnected)... so I think if it were "hotel" ish, wouldn't they need some type of interconnection between units? There are no halls, each unit has it's own exterior entrance.
Should I replace smokes and add the co2 combo at the bedrooms? Add more combos if the owner wants? replace smokes and tell owners to get the plug in co2's ;-) ??
Thank you
Thank you
