snadeau
- Baltimore, Maryland
I want to know how to wire this transformer from the following diagram.
I have 208 primary and want a 240/120 secondary
The only combination that has X1 connected to X3 is for 120 volt output, if you want 120/240 output you will not be using the configuration that has those two connected together.I wasn't sure if the x1 to x3 applied to the 120/240 voltage combination ; which doesn't make sense to me...
The "120" under "VOLTS" is one-half line too low, as is "X1 X4" under "LINES".I wasn't sure if the x1 to x3 applied to the 120/240 voltage combination ; which doesn't make sense to me...
And, as was mentioned earlier, that is not what you want anyway so do not worry about it.The "120" under "VOLTS" is one-half line too low, as is "X1 X4" under "LINES".
For 120V output, there are two jumpers: X1 to X3, and X2 to X4.
