Scotta9669
I am wiring a PLC to VFD. When wiring to the 24 volt relays is white or black the common. I know this is a silly question but my mind is going a thousand miles an hour. I know on a switch Black is common but.....This is eluding me.
Typically, in 24V signaling field wiring, white is grounded (or negative for ungrounded DC), black is ungrounded (or positive).I am wiring a PLC to VFD. When wiring to the 24 volt relays is white or black the common. I know this is a silly question but my mind is going a thousand miles an hour. I know on a switch Black is common but.....This is eluding me.
If you have single ended 120V AC and single ended 24V DC, they may share a commongrounded conductor which is not a neutral in either system. :angel:Try not to use word common sometime it is used for neutral
This is for control panels and machinery under UL (508?) or NFPA 79... AFAIK.In controls
Black = line voltage
Red = hot control voltage
White = neutral
Green = ground
Blue = DC voltage ( I use a wire ends red + Blk - )
