Two 100 amps
domnic
Electrical Contractor
I want to install a two gang 100 amp meter base with disconnects for each can I run the feeder wires in the same conduit in to the building ? what code article ?
If the disconnects are outside with the meters, then the downstream circuits are feeders, not services. You just have to remember to derate for multiple current-carrying conductors.
Are you dealing with multiple occupancies?
May not be acceptable in some of those instances to feed one occupant through another occupant space.
If you have a single occupancy with multiple meters there shouldn't be any problem.
