Got a call to a business that had non working exterior lighting. Opened the time clock and found insulation on load conductors burnt back about 2 inches from terminal.Time clock mechanism was melted at terminal where wires were landed.
I disconnected wires, rung out each conductor and found nothing grounded. I energized them and had an acceptacle amp draw for the # and type of fixtures that were being operated.Building owner states that C/B never tripped, he turned it off after seeing and smelling the burnt conductors. Out of the 8 fixtures on the exterior, I found one that needed a ballast replaced(150W HPS).Owner told me that fixture had been out for awhile prior to this problem. Time clock failure??? Loose terminal???, don't really know what to attribute it too. Any thoughts?
