Greetings,
I have a large material mixer that currently uses a 200hp D.C. motor. 1750 RPM 313 fla with a 300 volt field. We are installing an identical mixer with a 200 hp A.C. motor at 1780 rpm 480 volt 60 hz. I have been told that a 8 pole 800 rpm motor is able to produce about the same amount of work as the D.C. motor. My question is, are the two motors able to compete with each other (1750 RPM D.C. vs 1780 RPM A.C.)? The new 200 hp A.C. motor will be controlled by a VFD.
Thank you for any advice you may have.
