Tom Hedstrom
- Camden, Maine
Has anyone else had trouble with arc fault breakers on a 120volt leg of a 208volt service? When the load on the circuit gets up around 150 watts the arc fault breaker trips. This is a finished condo I walked in on today. My other guess is someone may have stolen the neutral off that circuit for something else, causing an imbalance. The only symptom I can find, other than the tripping breaker, is on the three way switching for that circuit I get 60-80volts to neutral and to ground on the runner that isn't being used at the moment. Has anyone seen/solved this?
thanks, Tom
thanks, Tom
