I have to feed some external sub-metering equipment from our 480 gear. I need a 3 pole 30 amp feed to this equipment. It has to be feed from this gear because the current readings and voltage must be from the same source. I have no available space for a small breaker and the gear is full.
I want to make a tap inside the gear to feed this equipment off the 2000 amp bus. Applying the 10' tap rule and using a tap conductor with 1/10 the ampacity would make a really big tap conductor for a 30 amp feed. If I fuse the TAP conductor before it leaves the gear am I still required to use that large of a conductor?
