ElectricVette
Here is the problem... the house is 4 years old very nice custom home. The water has a aqua blue color when you first run the faucets then clears out after a few seconds. Blue ring in all the toilets ect. House has a Ufer ground, gas hot water for in-floor heat and domestic hot water. 200 amp CH panel all grounds and neutrals tight. Power company came out and tighten the wires on the line side of the meter. I pounded a 8' ground rod outside and ran a #10 copper into where the bond hits the gas and hot & cold above the water heater. We turned off the 200 main and my meter still read 1 volt DC! Crazy i say crazy! :happysad: Could it be electronics inside the house bleeding voltage and/or a poor ufer? Any ideas on where the mystery voltage is coming from?
Thanks Tim
Thanks Tim
