Modular System
Modular System
[/QUOTE]
This is a very odd nameplate for " just " an AHU, as it shows compressor and charge DATA. Since it shows ampacity of OUTDOOR fan, it appears to be a remote air cooled unit. If you open it up I would expect to see a compressor inside. Its a type of package unit by the label.
I have seen and worked on similar ones made by Carrier and others.
It calls for 15 AMP protection with no heat pack.
30 AMP protection for 10KW of heat.
35 AMP protection for 15KW of heat.
These ampacities appear to cover everything INSIDE that cabinet.
AS thus, COMPRESSOR, BLOWER, HEAT PACK, etc.
By Model number standard convention its a 3 Ton compressor. [36000 BTU]
Its badly labeled.
I would call the OEM and ask to speak with Engineering.
