stew
- federal way,washington
Was told recently by an inspector to remove and replace the Bronze split type clamp on a ground rod because it was not installed per listing and the only thing acceptable is an acorn??? Mind you this is a Raco c-11bdag1r bronze clamp . Its the one that comes with the little paper tag "approved for rebar3-8" " suitable for drict burial in earth or concrete" Designed of course for many grounding applications. Now I cant use it for a clamp on a grounding electrode. ? HMMM Exisiting rod was of course 18 inches above ground and the installer way back when of course used his 16 lb mall to drive it so the head is all mushroomed. Used my Ground pounder and drove it home! Then used a split connector cause an acorn wouldnt go over the mushroom from the original to the new supplemental.! Nope gotta take it off he says and replace it with an acorn. lolol. Really? Passed it of course but said make sure and come back and change that. I agreed with a nod and my fingers crossed behinfd my back. lol. Unless someone can prove me wrong it stays just likes its supposed to.
do you suppuse this is a new requirement that only he knows about?
