veera1257
- hyderabad,Andhra pradesh,india
We have 33kV/330V transformer in our solar plant and it's LV side is connected to INVERTER. As per inverter manual we connected its 3 phases to INVERTER and Neutral is left opened and untouched (Floating neutral). We needed cooling for our inverter hence we used Air-conditioner for INVERTER room cooling, for that we took supply from transformer LV side and we connected neutral of air-conditioner to the Floating neutral of transformer and when checked meter showing 190V and we installed a stabilizer and gave stabilizer out put to AC.
AC worked for 4 days properly and later we found that sparking is coming from the Neutral joint though there is no loose connection.
What could be the reason for this and let us know how to resolve this issue.
Thanks in advance.:angel:
