georgeswe
- The Republic of Southern California
So I have multiple panels feeding line power to feed line contacts in a Musco lighting panel. The guy actually installing the lighting and connecting to the load side of the musco panel is supposed to install #4 wire to his fixtures. My question is since Im feeding the module in the musco panel with a 20 amp circuit breaker, do I have to install #4 from my 20 amp breaker to the line side of the lighting control panel. This whole question is compounded by the fact that I have to create all of my wire since I'm running all wire thru a gutter with over 30 conductors. The way it stands if I had to derate for Voltage drop and on top of having to derate the gutter my 20 amp load would have to be fed with a 3/0 wire while in the gutter. If I didn't have to derate for voltage drop my wire size would be #6. The panel to the lighting panel is about 25' feet apart.
