- Lockport, IL
- Retired Electrical Engineer
On a US Military base, the service to a new building starts at fusible cutouts on top of a power pole. The government, not the utility, owns the pole and the overhead distribution system. The voltage is 13,800. The building's service transformer is 2000 KVA, with a secondary of 480/277V. Transformer primary and secondary protection is from fuses built into the transformer housing. Pole-mounted fuses would therefore only protect the primary conductors. They are 1/0, 15kV, MV-90, will be routed from the base of the pole to the building in underground ductbank, and have an ampacity of 200 amps. The contractor has asked me to select the type and rating of the fuses.
I am OK with using 200 amp fuses, but I don?t know one type from another. Anyone have a suggestion?
