You are required to use a Chapter 3 method unless the power supply is listed as Class 2.
Even if the supply is listed as Class 2 using small gauge wire such as thermostat wire is a bad idea. The voltage drop is going to greatly effect the lighting performance. There is 10 times as much current on a 12 volt lighting system as there is for the same system operating at 120 volts.
