Fulthrotl
~Autocorrect is My Worst Enema.~
- E
is it legal to code?
i have a 75 kva dry type transformer, 480 pri, 120,208 sec. nema 3r
300 pounds or so....
i want to mount it next to a building, in an area not accessible to vehicles,
a planter if you will. nothing will be within 10' of it.
instead of forming and pouring a slab for it, could i use
one of those green pads they set A/C units on? put it
over a scoop of 3/4" gravel, level it up, before i put the
pad down, drill it and put 1/2" bolts up thru it to bold
the transformer to, so i have studs sticking up, and just
bolt the transformer to it before setting it with a crane?
i doubt it weighs any more than an A/C unit. would there
be any code violations?
