bschauer
New member
- St Paul MN USA
I work with welding systems that are connected to ground rods installed inside large buildings. A hole is drilled into the floor and a rod driven into ground, then bonded to the machine frame. It also seems to be a requirement for plasma cutting tables. I have asked what the purpose of this practice is and I cannot get a consistent answer. Many different opinions and some seem plausable, others do not. Is there aanyone out thtere that knows the engineering behind this practice.
