DBoone
- Mississippi
- General Contractor
Quick story:
Several months ago my uncle had to replace the cable from the panel to his electric range. I told him needed a 4 wire cable and 4 wire range cord. Well he got the 4 wire cable but didn't want to spend a few bucks to change the cord and receptacle. I tried to explain to him but e just doesn't understand. He said "the 3 has worked just fine, I don't understand the beauty of the 4." I finally have up and let him do his thing.
Now, I think he landed the EGC and neutral together on the receptacle and then landed each one one the neutral/ground bus.
My question: if either the neutral or EGC is compromised/severed, will you have full line voltage on the range side of the break? Or no because we still have an unbroken circuit (the other conductor)?
