Four way switches
HEYDOG
I have a question about 4 way switches. Some come marked input and output. I know that it will work regardless but as far as listing goes does it really make a difference as to which side the travelers hook to. I am thinking that it is just a way of helping the installer make sure that each set of travelers get hooked to the proper set of screws. Some of them just come with different colored screws. What are your thoughts.
iwire
Massachusetts
I will have to check on Monday. I think that it is Leviton.
Seems so.
I just grabbed this from the Leviton website
ibcGetAttachment.jsp
GoldDigger
Placerville, CA, USA
Retired PV System Designer
... Some of them just come with different colored screws. What are your thoughts.
When you use different colored screws, you have to guess whether one color marks input side and the other output side or whether one color marks traveler wire 1 and the other traveler wire 2 (in the "normal" position of the switch).
