- NE Nebraska
Simple explanation is the energy surge sent back through the lines when the magnetic field in an inductive component of the circuit (the motor) collapses - usually when the current is interrupted somehow.Explain 'inductive kick back'.
It is the basis of how they create a spark in the ignition systems of older internal combustion engines that used "breaker points" to trigger the spark.
Your well known brands of GFCI's have their circuitry designed to withstand a certain amount of kickback without tripping, but many cheap ones have more nuisance tripping issues and part of it is because this inductive kickback is not filtered, or not filtered well enough.
