HackElectric
- NJ
This is mainly for companies that do service work.
The rate that you use to price jobs is often based off of a lower billable efficiency than construction. Many people say to base your price off of 1,000 hours per year because there are so many unbillable hours when doing service work.
So the question is, when you are doing work that takes all day, are you using a lower rate? And if so, how did you determine it?
I know that I have read some people doing this.
For example, your normal hourly rate that you estimate jobs with is $150/hr. If you are going to do a full day job, would you lower it from that $1,200 down to $1,000?
