Westcoaster
 - Victoria, BC
Given a 200A residential service panel, horizontally mounted with 1-1/4" airspace behind (on 2x4 across existing studs)...  This orientation is inspected and approved.
Currently the branch circuit section located at the top is pretty much full, all future capacity needs to be added to the bottom section, as the branch circuits come to the panel via the joist spaces above then run down the wall, can the circuits be neatly routed and properly clamped to the plywood behind the service panel itself and then up into the knock-outs located on that lower side?
I could not find reference to this in the NEC.
Thanks!
Thanks!
