Copperclad
- Merritt Island, FL USA
Hi guys, Just a quick couple of questions , if you would not mind sharing your input.
We are currently wiring a Donut Shop ( you would not believe the equipment it takes to make one of these franchises work!)
Anyway, we would like to install a 100 amp sub-panel in the knee space of the front counter millwork to feed all the various appliances. There is a chase built in to the millwork to accomodate electrical plumbing, and POS respectively. The whole front (customer side ) of the millwork has very easily removed kick panels to inable access to all the different recpts. The engineer is telling me a sub-panel in this area would be illegal. #1 because the panel would be behind a removable kick panel, and #2 because the panel would be only about 8" off the finished floor.
We are currently using 2008 NEC, and I cannot find anything to prohibit this install. Any help would be apprecitated!
ps: the panel would be facing out towards the customer side, so once the kick panel is removed the panel is right there, very accessable in my opinion.
Must also note to add: These panels are removed without using any tools what so ever, just lift up and out, and thats it!
Other contractors have used this design, and to my knowledge never had any problems passing inspection.
Thanks everyone!
Thanks everyone!
