mshields
 - Boston, MA
A client recently asked us to critique the work of an electrician who had performed work in one of their electrical rooms.  One of the problems was that MC cable was run through walls and the openings left unsealed.  The room is a normal electrical room and doesn't need to be fire rated.
The client wants to know two related things;
1. Do the openings need to be sealed and/or fire sealed.
2. If code required, can the hospital require the electrician to come back since the installation did not comply with applicable codes.
This is one of those things I confess to leaving to our specs to cover, the letter of the code unclear to me.
If it's a non-fire rated wall, I believe you would still need to have some kind of seal. True? If it's a fire rated wall, even though it doesn't need to be, I would think he'd be required to maintain that fire rating and put in the fire rated sealant. If true, would this be something covered in the building code? Is it covered in the NEC (I've never seen it)
I'd appreciate any feedback.
Thanks,
Mike
Thanks,
Mike
