i propose to run a string of outlets for a workshop in an unfinished basement, i know they need to be protected by GFCI
i know i have 2 choices, either use a different breaker in the fuse box or use one GFI at the first outlet and then continue the circuit out from there. i would prefer to use the "first outlet" method as it is the most economical and convenient. the chain has four 4"sq boxes with two duplex outlets in each box (8 duplex outlets total)
my only concern is having the 7 outlets down the line hanging on the terminal screws of the first GFI. will this connection be "robust" enough? perhaps i am being too analytical?
opinions are appreciated
thanks
btw - 12ga 20A line
thanks
btw - 12ga 20A line
