- Massachusetts
OK, a friend of mine and I are doing a small off hours project* and we had a wiring issue, my friend came up with way I would never have thought of. His plan worked as he expected but we have since change directions. I will fill in all the details later.
Here was the problem.
We have a control box that provides one, two wire 12VDC, 5 amp output that has three states
In other words the control box flips the polity of the terminals. This control box was designed to directly control a small DC motor in forward and reverse. However, we needed to control a 24 VDC, 40 amp motor with it.
He came up with a solution that only required one low cost trip to an auto-parts store, I will explain it later but wonder what other folks would come up with.
Thanks in advance.
(*Full disclosure, we are electricians doing work for ourselves in his garage, there may be adult beverages involved, any mention of the NEC or safety is strictly prohibited. )
- No output
- 12VDC, positive on terminal 1 negative on terminal 2
- 12VDC, negative on terminal 1 positive on terminal 2
Thanks in advance.
