Does the neutral conductor for a 120V photocell have to be the same one that's associated with the load its controlling? Is the neutral at the point of the cell only used to complete the switching function?
I can't think of the situation that would cause this question![]()
That is the situation I have. Lighting loads are located at the opposite end of the building and all I have is the switch leg at the photocell point.Thought if it was not a violation to do so I would just pull a neutral off the neutral bar in the panel instead of tracing out the unmarked neutrals for the 5 individual loads I'm about to control.Obviously the neutrals are present at the fixture groups because all the lighting worked via single pole switches.
I don't see why the lights and the photocell couldn't have different neutrals, but it is a good question. They would be controlled by the same breaker, so it seems safe, but is it Code compliant?
It would work, it would not be code compliant.
Just for giggles.... If I come out of my panel with a conductor (in EMT) set a 4 inch box and pull 2 neutrals and the hot to it and go 2 different directions with the hot by splicing it. If I take one neutral and go one way and go the other way with the other neutral that is a code violation?
I'm sure it is but please tell me where that is.![]()
No, multiple neutrals associated with a single ungrounded is not a problem.
And in addition to that, it is a current divider and in turn it becomes an EMF issue if it does not run in close proximity to the other all the way back to the panelboard.It certainly is if the additional neutral is also part of another circuit as is the case with the opening poster of this thread.
No all the conductors of the same circuit are in the same raceway or cable. Make everything the same except one neutral returns via a different raceway then you have a code violation, even if it is not shared with another circuit in any way.Just for giggles.... If I come out of my panel with a conductor (in EMT) set a 4 inch box and pull 2 neutrals and the hot to it and go 2 different directions with the hot by splicing it. If I take one neutral and go one way and go the other way with the other neutral that is a code violation?
