I was asked to look at a job where the incoming Voltage is 13,800 Volts to a residential High Rise
They want to install the following
High voltage Service room in Basement. 1 transformer step down 13,800 to 600 volts Switch gear 600 volts
Second run 13,800 Volts from High Voltage Service Room to Roof Area 1 Transformer step down 13,800 to 600 volts. Switch gear 600 Volts
Has anyone seen this type of an installation ?
Is High Voltage at 13, 800 volts NOT INCASED IN CONCRETTE OK
Are there any interference issues with High Voltage, communications, lighting, etc.
Any input is welcome.
Thanks
Thanks
