srinivasan
 - Bangalore,India
I am going through the specification of International marine std for incinerator [MEPC 76(40)] where it is mentioned "Two fuel control solenoid valves should be provided in series in the fuel supply line to each burner". Here i got doubt. If Solenoid valves are Normally closed type (Failed close-usually for fuel control operation) and one valve failed, other valve also will not do any work. If two valves are in parallel, this will be considered as redundancy valve but in series...  Can anybody clarify, purpose of connecting two valves in series.
