shalabi
- Damascus Syria
Hi all
What is the difference between
KW/month and KWhour/month?
Thanks
Thanks
Hi all
Thanks
kW/month makes no sense.Hi all
Thanks
Kilowatt-hour/month would be the average over time of what we get billed for on monthly cycles.Hi all
Thanks
for expressing larger units of energy of courseKilowatt-hour/month would be the average over time of what we get billed for on monthly cycles.
I have no idea what anyone would use a kilowatt/month value for.
One kW/month is a meaningless unit. It's like miles per hour per hour or miles per hour per week.One kW/month = one kw for one month:happyyes:
Depends on which month you are talking about though as a kW/month is sometimes 30 sometimes 31 days - then you have Feb to deal with.
"The total power generating capacity in the US is increasing at the rate of 1 megawatt per month," maybe?
Tapatalk!
No. That would be one kW-month, not one kW/month! See my example of where the /month would actually be meaningful.
Tapatalk!
Now if we just knew what context the OP has seen this in maybe we could straighten him out with understanding what he may be dealing with.
I feel like something went way over my head here:?Aw, ...... were not THAT bad of a group.
| Electricity (maximum demand) KVA/month | KW/month | kilowatt hours/month |
| Electricity High Voltage Requirement ______ Volts | 1/2/3 Phase | Diversity Factor / Power Factor |
Hi all
The following table is made by electrical authority in the Saudi Arabia
in order to fill in
They asked for KW/month and KWhr/month
. Power and Utility
I did not understand the difference
Electricity (maximum demand) KVA/month KW/month kilowatt hours/month Electricity High Voltage Requirement ______ Volts 1/2/3 Phase Diversity Factor / Power Factor
Please Help
Thanks
It is not "meaningless," it is merely "useless." Take a "rate" and divide it by "time" and you get "acceleration." GoldDigger had a good counter-example:One kW/month is a meaningless unit. It's like miles per hour per hour or miles per hour per week.
In this case, rather than calling it "acceleration," I would use the phrase "rate of load growth.""The total power generating capacity in the US is increasing at the rate of 1 megawatt per month," maybe?
I suspect that the electrical authority is actually asking for the maximum peak demand that you anticipate seeing during any given month. The units should be KW, not KW/month. I think it is likely to be a simple error in translating the requirement from Arabic to English.The following table is made by electrical authority in the Saudi Arabia . . . They asked for KW/month and KWhr/month . . . I did not understand the difference.
