Does anyone know where you can get metal clips for fluorescent fixture?
bjp_ne_elec
Southern NH
Not sure what they are technically called, and that may be why I can't find them on a search. These are two metal clips that hold the metal reflector that is just above the lamps. On this job where every single one has fallen out, and as it's a commercial building, they take off and end up lost. These seem pretty cheesy and everyone is distorted when it comes out. I have been able to get them to hold bette after bending back in to their original shape. I have to find replacements, but if I find a decent replacement, I'll replace them as I switch out the ballasts and/or lamps. I've checked Grainger but can't find them, and I've googled but have come up empty.
Thanks,
Dave
Have you tried your local electrical wholesaler. They may have some extras on hand or could probably order some from one of the lighting companies.
I found them ... called..... 1/4 turn retainer clips....... Epco has them.
Thanks. Have tried two local supply houses and nothing. Calling one that is 45 minutes away, and see what they've got. Definitely going to get a few packages for the truck.
Thanks
I just toss them and use Tek screws.
Same here but, I did have a bag of 100 sent to me once from a local supply house. I only asked for a couple and got a whole bag. I think they were Lithonia.
Roger
Belly pan clips. I have bought them at Home Depot. I hate them, as they do not hold well but pop out easily at the worst moments. I have sometimes drilled the light, put a long 1/4x20 bolt through and use a 1/4x20 wingnut on the bottom. I got the idea when I saw some wingnut looking clips on a few high dollar lights I installed in a factory. Takes a little time but is well worth it.
When you find clips, stash a few extra in your toolbox or truck. They get lost quite often.
