greenspark1
- New England
The situation- an existing service panel (call is Z) with a wireway above. The previous electrician installed a 4/0 ground up into the wireway terminating into an insulated busbar. This then runs to the building's water main.
We're adding a new panel (call it Y) 10' away. The new panel will be fed from Z. The electrician want to tap the busbar in the wireway and run a small conduit down to Y for the ground, and run a new conduit from Y to Z with the 4 phase conductors. This is 208/120V. Is this legal to have the ground in a separate conduit than the phase conductors? It feels wrong but I'm having trouble pinpointing anything in the Code, 250.134(B) seems like the right spot. Anyone run into this before???
