Does this switch a contactor? I ordered a new astro unit so I wouldn't need to screw with the settings anymore. And it kept spazzing out on me, maybe once every 2 weeks. I called the vendor and they said I needed a filter across the contactor coil. I had thrown these away when I installed it. So the local supply house got these for me they were cheap. And they fixed the problem. Haven't had to touch the thing in awhile.
I looked just now and the part number is Intermatic ET-NF.
If you're asking about ours, yes, they switch contactors. It has the same 1800VA rating you get out of any other ANSI C136.10 control. Most contactor coils draw around 20VA.
The person you replied to never mentioned having problems with the product he sells. I'm guessing you maybe were intending to reply to the OP?Well then, you might try the filter. I can't remember having to reset the time every time our timer glitched. What happened was the lights would fail to turn off or on. I think at least once the time reset on me as well. You might need 1 filter per contactor.
Are you saying the operator has no control over the scheduling of the lights? Is it just dusk to dawn?
This looks like the ticket. How does it install?
