ishium 80439
I'm going to be trimming out a basement finish shortly and the home owner wants to use gray devices. I was planning on using Diva dimmers but the problem is the that gray Lutron uses is different than the gray Pass and Seymour use (P&S being what my primary supplier carries). I'm going to have a few boxes where there will be both dimmers and decora switches and I think that mixing the two is going to look odd. I called Lutron and they could not give me any info on what other manufacturers may be compatible. So I'm wondering if anyone here might have any ideas as to who might match the color that Lutron uses. And as an aside they want to go with the screwless plates so I need to make sure that they are available from the device manufacturer also.
Thanks
Thanks
