An architect friend of mine wants to provide power at a well pump house for a 120V filter. The problem is he has 240 volt power only with no neutral. The existing 30/2 (1 HP) circuit consists of two phases + ground, with no neutral. Now, the well pump filter he is buying requires nil power @ 3W but is 120V. He also wants to pull a 120V GFCI circuit to an adjacent shed for a light and convenience receptacle. My options are...
1. Repull a new circuit to the well pump house using UF cable, Phase A, Phase B, Neutral, Ground. Derive 120V from this circuit via a small load center in the pump house. The run is approximately 150'.
2. Provide a small encapsulated step down 240/120V transformer (less than 500 VA load) to derive 120V for the well pump filter and any convenience outlets. Can someone make a recommendation for where to obtain such a small, light duty transformer?
Suggestions??
Thanks
Philip Neidlinger
Suggestions??
Thanks
Philip Neidlinger
