mhernandez
- Chicago
Quick question,
I have a project that consist of a new Zoo exhibit for monkeys and the exhibit architect is designing an in-ground, "hot tub", (technically a small pool with a heater), for the monkeys. Around it, they will have what they call "hot rock" surfaces which are pieces of shotcrete with radiant heating cables inside to heat the surface.
NEC article 680.27.C.3 indicates that radiant heating cables are not permitted on the deck area.
Is it wrong to consider these "hot rock" surfaces as not deck areas? Or should i just tell the exhibit architect that he cannot heat any surfaces within 20' of the inside wall of the tub with radiant heating cables?
Also, does this article only applies to swimming pools or my kind of hot tub falls under this article also?
Im just trying to understand the true purpose of the article.
Thanks!
Thanks!
