Using multiple power sources imposes special requirements on grounding design. First, you must determine if sources are separately derived or service supplied.
Maybe these threads will help: http://forums.mikeholt.com/showthread.php?t=120637
It's relatively simple to make the determination....
If you do not switch the neutral, will the other source and/or the grounding system be a parallel path for neutral current? If yes, the neutral is required to be switched.
