Barbqranch
- Arcata, CA
- Plant maintenance electrician Semi-retired
My understanding of why you should never use pvc for compressed air is that failures are catastrophic. Water compresses very little, so if the pipe cracks, the pressure goes down quickly as it leaks out. Compressed air, on the other hand, will keep pushing on the pipe longer, causing it to sometimes explode.
