FionaZuppa
- AZ
- Part Time Electrician (semi retired, old) - EE retired.
so this is interesting and not sure how i should proceed.
my home is on bad power, we get ring wave spikes due to old switching on utility side, local cement plant is part to blame too.
my panel had some GFI's in it, but due to ring waves hitting the panel some of the GFI's would trip. after digging into the issue the electrical company who installed the panel replaced the GFI's with Eaton BRAF's.
so, my "issue" has seemingly gone away. i continue to get hit with power dips/spikes. however, the BRAF's are not in same class as GFI (AF ~30mA while GFI ~5mA).
now i am doing spa out back along with outdoor kitchen. my plans called for GFI breakers. i suspect these GFI's will trip when i get hit with ring waves.
does NEC allow the use of "AF" breaker for pools?
i have been battling with utility for a long time. i even have a DataQ device recording my line power so i can show utility that this is a issue they need to fix.
