- NE Nebraska
I am not expert by any means so I may learn something too but I don't believe there really is an AC resistance, if it is AC it is impedance and it seems every detail of circuit can change the impedance. From the raceway type to the layout of the conductors.
But I think most of us electricians do like George, treat it like DC and call it good enough. Engineers would go deeper and make it right.
I will not claim be an expert on this either, but I believe that with AC RMS voltage with little or no harmonic distortion you can treat it like DC at the same voltage - as long as you have resistance loads, throw in some capacitive or inductive loads and things get more complex, although impedance is still measured in ohms and can be plugged into the same formulas as resistance - and be close enough anyway in most cases.
The tricky part of impedance is it is a different value when not energized then it is energized, and this gives you that "inrush" current when first energizing.
