Jedd
- hauppauge N.Y.
my 4 wire hot tub was wired 3 wire. 2 hot -ground. My electrician pigtailed the neutral at the tub to the grounds
I call the local building inspector , he is coming on Tuesday. Don't want this guy to lose his license. ?????? He was aware I was
going to get it inspected. Advice ???
Probably not, it would have tripped with the neutral current flowing back on ground, unless he ran the ground through the GFI breakerDid he use a gfci breaker?
He needs to loose his license--- I would call him first and have him correct the install. He may not be licensed anyway
#6 wire flat one 6/2. guess he should have used 6/3 . can a neutral be added it is in 3/4 conduit.
better just to have him run all new wire. Its about a 50ft run
