Strombea
- Prescott, Arizona, USA
Quick question:
Why do we have two different systems when one system 120/208 or 120/240 (3 phase or single phase) would be easier as all double pole equipment would be the same voltage?
Just curious as to the big picture difference, and if 120/ 208 Y is more efficient then why don't we put that in residence?
Reason for question is that I was called to a high school needing a 240 v hook up for a new espresso machine in the snack shack, but the panel was 120/208 3ph of which was not sufficient per manufacture specs, frustrating because if everything was on one system (except maybe industrial and heavy commercial), it seems that these situations would be much easier, efficient, and quicker. Otherwise you have to shop around for the correct equipment of which 240v is more common.
Is 3 phase 120/240 common?
Food for thought, no issues, just curious.
