No detached building wiring coming up, but wondering.
It never made sense to me how if a panel is installed, that an exterior disconnect is needed, or the panel would need to be located right as you enter.
What about a house where that panel is fed from? Around here most main panels (and disconnect) are located behind locked doors usually down in the corner of a basement.
Doesn't make sense.
If there's an exterior disconnect, does the driven rod (or two) go to the disconnect ground, or the panel ground.
From what I understand, one circuit does not need a disconnect at the detached structure, But two or more circuits would.
How do you do it? 2 pole and 3 pole switches in exterior boxes? Or ganged up single poles?
Could what ever disconnect that is used also be right inside the entrance?
Where does this leave a light that you want. A light on the detached structure and the house which come on together. And the 3-way switch at the detached structure that controls those two lights?
Thank you
Doesn't make sense.
Thank you
