electro7
- Northern CA, US
- Electrician, Solar and Electrical Contractor
Hi,
I will be installing a 240v delta to 208v wye transformer and was wondering if I need a main breaker for the panel I am feeding from the secondary side of the transformer? I have a fused disconnect on the primary side. The transformer, fused disconnect on the primary side and the panel I will be feeding from the secondary side are all within 10ft of each other, if that matters. Could you give a code reference.
Thanks!
Thanks!
