Traffic Control
- Orlando Florida
My question is regarding the ?shell? voltage radiating out from a light pole with no effective ground-fault current path. I am assuming that if there is a ground fault by the HOT wire in contact with the metal light pole outer edge, the fault current is trying to find it?s way back to the earth grounding rod at the closest service. I have two questions:
1) given a fault by the HOT wire on to the metal pole, could fault current find it?s way back to possibly 2 service locations?
2) If there is only 1 service location for the light pole, will the ?touch voltage? radiating out into the earth shell from a short by the HOT wire to the metal pole be symmetrical circles of voltage potential or will the ?touch voltage? be higher between the pole and the service, versus the other side of the pole (the side of the pole NOT between the pole and the service)? In other words, if an electrician was standing on the side of the light pole that is not between the service ground rod, would the ?touch voltage? be the same? Thanks!:?
Please feel free to correct and wording or technical terms.
