Brian Williamson
- Kansas
I'm currently finished wiring 2 homes in emporia ks, the bedrooms and smoke detectors are on arc fault breakers, and the entire kitchen is GFCI protected, also the garage is GFCI protected. I failed my final inspection because the living room receps were not on a arc fault protected. During the conversation the inspector also stated that my lighting circuits have to be on an arc fault breaker.... I can't find in the 2011 code under 210.12 where lighting doesn't require arc fault breakers. I'm sure some of you guys know the answer to this, any help is appreciated
