The old reeves drives are a mechanical vari speed. They have a new system called the Innovadrive. Its a direct drive motor to the reducer with a VFD controlling the motor. Look it up its pretty cool.
OK, I see now.
mike_kilroy is right, they don't make it, which likely explains the bad answer you got from their tech guy, because he apparently has no clue since he is so far removed from it. Here's the chain of possession, it's a little convoluted...
Master PT is brand labeling it from Leeson as part of a package with the motor. But Leeson doesn't make it either, Leeson brand-labels that drive from another company called AC Tech. But AC Tech is now owned by a German company called Lenze, who is who actually makes that drive (AC Tech used to make drives here in the US, but when Lenze bought them, all the new models come from Germany). So by the time info filters down from Lenze to Master PT, it gets to be kind of like that old "Telephone Line" game where the stuff that gets out at the end of the line barely resembles the original message.
They do have 240V drives, and FYI, the input voltage range of the drive is 170-264VAC, and for 4
80V drives it is 340 - 528VAC. So he definitely had no clue...
Being that they are German drives, they are not designed to be operated from
ungrounded delta systems, at all, period. But again, you have a corner grounded delta system so that's fine. They do make a reference to issues with control circuit isolation on corner grounded 400-500VAC systems, but no issue mentioned on a 240V delta. I would not worry about it, but don't buy into the "kit" concept, tell them you want a 240V drive, or just use a 480V drive. Apparently the problem is that Master PT does not
package this system with anything other than a 480V drive and motor, but trust me, they could do it for 240V, you just have to find the right person and the one you spoke to is not the guy.
