Strombea
- Prescott, Arizona, USA
I'm just starting to get into these panels as i have always stuck with residential work. (so take it easy)
1. Why a high leg at all? What are you supposed to put on it (high leg) when all you need is 120v for computers and lights? And are you supposed to just put a blank filler on every 3rd breaker if no need for 208v because voltage is too high? (thus a third of the spaces are useless when no phase to phase load is needed?
2. Is there a difference between 208v from phase to phase and 208v high leg phase to neutral? example: a copy machine needs 208v, so do you run one single phase load to neutral or phase to phase load? the machine is getting 208v either way- Does it Matter?
I really don't understand the reason for a high leg.
Thanks for the wisdom shared!
