liquidtite
- Ny
I was told that when you have a 480v wye system
you can't use orange as b phase color in ct cabinet ,You have to use a diff color so that utility company knows not to give you a delta high leg
. Also isn't the delta high leg system 120 /240 and on the b phase you'll get like 208 to ground
or can you get a highleg system in 480/277 v as well
if any one has the time can someone write down all the diff electrical systems wye and delta so I can write th?m down . Thanks for your time
